WD45 Lubricants for transmission
CTV
09-03-2006 22:59:56
Can anyone tell me if 90 gear lube goes in everything to the rear of the hydr. oil fill. Is it 90 weight that lubs the hand cluch? I have ordered a manual but there is water in Transmission oil so I want to change right away. Thanks to any one who can help.
JMS/MN
09-04-2006 11:07:26
 Re: WD45 Lubricants for transmission in reply to CTV, 09-03-2006 22:59:56
Manual calls for SAE 20W above 45 degrees, SAE10W below 45 degrees for hydraulic system. Final drives, transmission, differential, and transmission clutch use SAE 80EP all year.
Andrew Fischer
09-04-2006 06:44:47
80 90 will work just fine. Use quick lift for hydralic.
