WD running rough
Justin Squire
09-02-2006 15:50:31
My Wd is running very rough at certain times. Usually after I start it, it runs very good and smooth. After driving it for a little bit, it starts acting like it is going to stall. It has actually died several times, but I have been able to start it again. I am not sure why, but I have heard that it could be the manifold gaskets. Does it sound like this. It also could be the timing, but I don't think that it would just act like that some of the time if it was the timing. It also could be a fuel problem. I have a new sediment bowl, and there appears to be about a 1/16 of an inch of sediment on the bottom already. Also, should I try the power or idle screws on the carburetor? Any help would be appreciated.
Andrew Fischer
09-04-2006 07:12:10
 Re: WD running rough in reply to Justin Squire, 09-02-2006 15:50:31
Ist pull you fuel line off on your carb end and check for good fuel flow. If you have good flow it may not be a fuel problem. Make sure you are running a filter in the sediment bowl! If not getting good flow. It may also be a rusty fuel tank. I had had this happen many times. I would make sure the tank is faily clean. Drain old gas. Put on a new sediment bowl and pull the drain plug on the carb and let fresh gas run through intil it looks clean. Normally if a coil or points fail it will not get any spark and will not start in the first place.
maricopa
09-03-2006 21:18:49
My b did the same thing. Turned out, it was restriction of fuel at tank to bowl. Take bowl off and clean tank (flush). Also make sure cap is vented. Could cause vapor lock after a short time running.....
Let us know what fixed it.
RandyN (MO)
09-02-2006 18:35:25
Hi Justin,
You know, I'd bet a dollar that it's crud...little pieces of rust...getting into the carburetor and plugging up the small holes in there that are ever so important to be open.
My C behaved like that after I got it. I cleaned out the tank and the carburetor and it seemed like just a little bit of crud will make it not run right. One behavior mine did was that the crud would plug up the idle jet. It would run okay but if I throttled it way down it would die then not start for a while. I cleaned some more and was brush hogging with it and it would run rough, clear up and run BEAUTIFULLY, then run a little rough, then clear up and run sweet again. Now, it runs nice all the time.
One thing I like to do, because I don't like the looks of an in-line fuel filter, is I clean out the tank then get a fuel sediment bulb that's intended for Ford N's and Fergusons. It has the dial that says "2 turns main, full open reserve" and on the stem inside the tank it has a screen around the intake and a pipe sticking up inside the screen. No more crud problems. The threads on those fuel bulbs are the same, so it will screw right into your tank. The fuel bulbs labeled for Allis tractors take in fuel at the bottom of the tank with an open hole. Some people like to put a riser pipe into the hole of the existing Allis fuel bulb.
Good luck!
RandyN
Justin Squire
09-02-2006 19:21:02
 Re: WD running rough in reply to RandyN (MO), 09-02-2006 18:35:25
How would I clean the fuel system? Should I take off the sediment bowl, fuel line, and carburetor and clean them all? What should I do to clean the carburetor. I have already rebuilt it, taken it apart because of a piece of junk in the needle valve causing it to leak, and put it back together. Should I take everything apart and clean the passages again or can I do it without removing all the jets and the needle? Also, should I try to clean the fuel line or just get a new one? I did not do anything to the line before reinstalling it. I did have the fuel tank professionally cleaned and lined, but it still looks like there is junk in the sediment bowl. Thanks for the reply and if you have any answers to this question please contact me.
RandyN
09-03-2006 07:42:07
 Re: WD running rough in reply to Justin Squire, 09-02-2006 19:21:02
I've had good luck getting the carburetor to work right by draining the fuel out of it and blowing air from an air compressor. To truly clean it, I take it completely apart and bead blast the body then blow every nook, cranny and hole with compressed air.
As for the fuel tank, I drain it, take it off, and then slosh a little fuel in there. Let it dry then shake everything I can out of it. I've heard people talking about putting a little clean gravel, or some other form of abrasive beads, to help knock more loose. I've never done that, though, and have had great success. Some people like to put that liner stuff in the tanks and swear by it. For some reason I don't trust the liquid liner...it seems a few years down the line then that liner is going to peel or flake...time will tell, though.
It probably wouldn't hurt to blow compressed air through the fuel line if it has a low spot in it.
RandyN
old
09-02-2006 19:37:18
Buy an in-line fuel filter from either a motor cycle place or lawn mower shop then put it on. DON'T get one from and auto parts store or it will cause you problem
