Fiat Allis 100 C motor grader
John H Boy
08-31-2006 19:40:56
I bought this motor grader at an auction and just noticed that the transmission fluid is milky looking. I assume it has water in it. If so, what may cause this and how do I fix it?
Michael powell
06-11-2007 11:28:27
 Re: Fiat Allis 100 C motor grader in reply to John H Boy, 08-31-2006 19:40:56
Hello steve how are u doing today i am interested in you fiat allis 100c motor grader parts i will like to buy such as ring pistion,con rod bearing and main bearing and oil seal front and back ...i will be looking towards your reply soonest....Pls get back to me with more detail and method of payment and also if you have a picture for me to see ....i will be expecting your reply at [email protected] .....Bye
steve(ill)
09-01-2006 15:01:37
the most common cause of water in any transmision is rain. it goes in the breather or the dip stick hole, or around the shift lever boot. if it was antifreeze you should see quite a bit of green in it. i would assume it is rain waster, drain it out, refill with good oil, run a coule hours, drain and refill again. dont flush with diesel fuel or something like that, just do two oil changes. you will still see some left over after the first change.
micheal powell
06-12-2007 05:37:29
 Re: Fiat Allis 100 C motor grader in reply to steve(ill), 09-01-2006 15:01:37
We will luv to know more about it.....and interesed in purchasing it ...We look for ya reply soonest
