1937 AC WC
Rex37WC
08-31-2006 18:14:30
Calling all Allis Chalmers experts! I've had a '37 WC for a couple years, rebuilt the carb, steering system, and put on a new manifold. What's got me puzzled is 1st gear is faster than 2nd gear. I killed it a couple times trying to get it on the trailer (in"1st" gear)the day I bought it, and after I got it home and ran it for a while I understood why. How did this happen and how do I fix it? Is it possible someone put a gear or two in wrong? I haven't taken the transmission apart yet. Also, even with the carb rebuilt, new manifold and no air leaks, it still idles best with about 1/2 choke on. Any ideas?
rex37wc
09-06-2006 12:28:10
 Re: 1937 AC WC in reply to Rex37WC, 08-31-2006 18:14:30
Butch, After all the work described was done it idled and ran perfectly for a while. This year it didn"t. Today I did found what I think is an air leak. On the Zenith carb. above and behind the air adjustment screw is a flat spot in the casting that faces the motor at @ 45 degree angle. There is a hole in that flat spot that I can hear air going into. Should that hole be plugged? I sealed it last year, but the seal gave up this year. There is a similar flat spot with a small hole that faces away from the engine, but doesn"t seem to draw air. The motor runs just as well with the air screw in the carb or in my hand. If I spray carb cleaner into the air screw hole, the engine falters. The air screw is also very loose in it"s threaded hole. I made a leak finder with a pair of hearing protectors, vinyl tubing, copper tubing and brass fittings. This one has the flattend pipe on a 45 degree elbow exhaust and you cant"t hear much else when it"s running.
David Maddux
08-31-2006 19:50:11
I had a WC that did the same thing. The shifter was worn enough that it was going in third instead of first. You just need to take the shifter lever to a machine shop and have the groove rebuilt and the go to Agco and buy a new oversized shifter pin. Then it will be as good as new.
rex37wc
09-06-2006 12:10:29
 Re: 1937 AC WC in reply to David Maddux, 08-31-2006 19:50:11
David, Thanks for the direction. Today I found first gear by moving the shifter to the left a little farther than I could comfortably reach. Sounds like a nice little winter project.
Butch(OH)
08-31-2006 19:02:36
The idle problem is a too lean mixture, simple as that. Since you seem to be sure it has no air leaks the other possibilities are fuel supply, although that usually affects operation under load more than idling, carb passages blocked or throttle shaft and bores worn out and sucking air past the shaft(only seen one that bad) The other problem would be easier to figure out if one was able to see the thing, lots of questions. Are you sure you had it in 1rst and not 3rd? On our WC and WF with rebuilt towers it takes a conscience effort to put them in first otherwise they go to third instead. If your getting it into the right gear is 2nd slower than 3rd? Do the other gears seem to be the right speed and only 1st is off? Been too long since I had the top off of a WC trans to tell you for sure if the gears could be put in wrong. Im think'en that reverse runs on the gear for first on the countershaft, if so you wouldnt have reverse if the gears were not in the right place unless somebody custom geared reverse so they could put the forward gears in wrong, dont make sence but I have seen more 'tupid things done.
rex37wc
09-06-2006 12:34:02
 Re: 1937 AC WC in reply to Butch(OH), 08-31-2006 19:02:36
Butch, I sent a reply to your advice for my problem but didn't get it in the right spot in the forum. It's under my original post. Anyway, I think it's time for a full sparkplugs, wires, and valve adjustment tuneup in addition to whatever carb. work is needed.
Rex
