G gear oil
Paul ML
08-31-2006 17:27:13
Hi folks, I hope someone will be willing to answer a pretty basic question- what's the correct gear oil for a G? I emptied mine before realizing that I don't seem to have a manual!
Thanks,
Paul
DanD.
09-03-2006 18:52:27
 Re: G gear oil in reply to Paul ML, 08-31-2006 17:27:13
You don't want to use 90 wt gear oil in any G with hydraulics or not. THere are a couple of bearings that are lubricated by oil thrown by an oil slinger and the #90 doesn't get there very well. Use a modern trans hydraulic oil in all G's.
steve(ill)
09-01-2006 15:05:29
several types of oil have been used over the years. the 90 wt gear lube sometimes quiets the noisy gear mesh. 20 wt was standard fill from the factory. i think the thinner oil helps get lube up to the upper bearing area on the top shaft. many guys these days use a universal hydraulic transmission fluid. you cn also use Hytrans or other hydraulic/ trans fluids. they are basically a 20 wt oil with antifoam and addatives for high pressure hydraulic systmes.
Joe M(GA)
08-31-2006 18:04:30
For mine without the hydraulics I use 90 wt gear oil, the one with hydraulics I use 20wt motor oil
