Starter bendix gear
SHade Tree Repa
08-31-2006 06:06:07
A friend is repairing an HD3 dozer for use on the farm. He has had the starter rebuilt and now it will not hit the teeth on the flywheel gear. It currently has a 9 tooth gear. Is there an 11 tooth gear available? He needs help locating the correct drive gear. Thanks in advance
Ol Chief
08-31-2006 08:19:11
 Re: Starter bendix gear in reply to SHade Tree Repairs, 08-31-2006 06:06:07
There is not quite enough info.to give you much help.For instance,I have several Minneapolis Moline tractors.Starters on 335 and 445 series look identical and are, except for the length of the armature shaft.The bendix assy. and pinion are the same.The 335 pinion cannot reach in far enough to engage the flywheel on the 445 because the shaft is 3/8 " too short. If your friend had sent the starter out for overhaul does he know if the armature was changed? Also was the bendix or pinion changed.If so can there maybe,be a difference in the pinion. That however is doubtfull,mainly because there is a limit to how far to pinion can travel.Number of teeth on the pinion has no effect on engagement of pinion to the flywheel,but the pitch and diameter must match or something will be torn up.Changing pitch of pinion will find you more problems. I think you need to examine the length of the shaft as well as the bendix.Also could the endbell of the starter have been inadvertedly have swaped.
