190XT hydraulic problems
Roger in Texas
08-29-2006 19:47:29
For years the lift on my 190XT has not been 100% so I decided it was time to fix it. I installed a new pump and the lift is no better than it was before and the new pump makes a hissing/squeling noise. I was told it is because it was not getting enough hydraulic fluid. I checked the sump screen and it is clean. I bled the line of any air and the fluid is clean. I have replaced several hoses and connectors to fix and minimize leaks. The pump is a triple stage. The tractor is an early(1966)190XT Series III, serial #10944. I have the service manual and it shows an OTC hydraulic tested use to check flow and pressuse. Does anyone have a lead on an inexpensive hydraulic flow/pressure tested and/or know what I can try next to fix the hydraulics ASAP...I am lost without Allis? Thanks in advance for any advice.
