G transmission stuck update.
B. Jones
08-29-2006 19:36:47
Thank you guys very much. I pulled out the gear shift lever after I took out a snap ring. I had to move the super low back about 1 inch and that fixed it. I put the shift lever back in and it works fine. One more Question. Is it positive ground or negative ground? I put in a good used battery back like it was with negative ground. It starts and runs perfect and is charging good but the amp meter charges backward. I think it must be positive ground? If it is positive ground should I change it? Thanks again guys. B. Jones North Central Missouri
B. Jones
08-31-2006 04:17:15
 Re: G transmission stuck update. in reply to B. Jones, 08-29-2006 19:36:47
I turned the battery around yesterday for the positive ground. I polarized the generator and now it charges on the correct side of the gauage. Everything is working great on the little tractor. Thank You guys for all your help on this little tractor. The little thing sure is cute. B. Jones
CHALMERSBOB
08-30-2006 18:55:34
GLAD TO HEAR YOU FIXED YOU TRANNY PROBLEM.
YES IT IS POS GROUND, MOST ALL GENERATORS ARE. BOB
BCnT
08-30-2006 08:20:35
if its charging just swap wires on back of ammeter and polarize generator just to be on safe side.
