Allis Chalmers Tag
rockyroad
08-28-2006 12:44:38
I found a tag on a the left side of the engine that was "15 4787R" Can some tell me if this is the ID tag for the tractor, or a tag identifying the engine block? If it is the Tractor"s ID, what does it tell me. Any help would be greatly appreciated.
CHALMERSBOB
08-28-2006 19:49:11
 Re: Allis Chalmers Tag in reply to rockyroad, 08-28-2006 12:44:38
IS IT A BRASS TAG ON THE CARB? TRACTOR ID IS STAMPED INTO THE CAST IRON. THE LOCATION WILL DEPEND ON WHICH TRACTOR YOU HAVE. MOST 24" TIRE SIZE TRACTORS HAVE IT NEAR THE GEAR SHIFTER. EARLY WC WD WD45 28" SIZE REAR TIRE TRACTORS HAVE IT ON THE REAR END, WC CENTER, WD, WD45 BELOW THE LEFT BRAKE COVER ON A MACHINED SURFACE OR LATER ONES, D SERIES,ON THE BELL HOUSING. BOB
