Finishing mower on Model C
Jim Hunter
08-27-2006 13:27:46
Would like to put a finishing mower on my Model C. The mower I am looking at needs 540 PTO speed and designed for 20 - 40 HP Tractor. Would this work on my model C? Would I have to rig something up for the driveline or will it attach to my PTO?
phillipledford
08-31-2006 13:25:19
 Re: Finishing mower on Model C in reply to Jim Hunter, 08-27-2006 13:27:46
I have a woods rm 59 finish mower rated @ 540 pto rpm,That i pull behind my AC B It seems to do a real nice job without any trouble,I made the 3pt lift for tractor but decided i needed alittle weight on the front whenever i was using the lift so i made some weights from RR track each weight is almost 85 pounds,other then the weight problem everything worked fine.I will try post a pic if anyone is interested (Sorry for posting twice)
ScottAC
08-30-2006 06:20:38
I have a Woods L306 mounted on the belly of my C. Runs of a belt pulley mounted on the pto. Tractor has hydralics for lifting & lowering mower, this is a mowing machine! I would look for a L306 model mower - 6ft cutting width.
Dick L
08-27-2006 17:56:42
 Might Tale A Peek in reply to Jim Hunter, 08-27-2006 13:27:46
At the Ebay link below.
old
08-27-2006 13:35:02
Theres a good number of them out there both belly mount and pull type. Also 3 point types that would work if you have or add a 3 point. I wish I could find a belly type for my C, it has a sickle mower that belly mounts but I want a lawn mower type also. Then my wife would use it to mow the lawn with
phillipledford
08-31-2006 12:45:02
 Re: Finishing mower on Model C in reply to old, 08-27-2006 13:35:02
