Wiring Diagram with 1 wire alternator setup for Al
YYYYYY
08-26-2006 14:57:58
Can anyone out there provide me with a wiring diagram for a 1 wire alternator with the internal regulator for use on an Allis G Tractor? Thanks.
Kent of SW MO
08-27-2006 15:33:18
 Re: Wiring Diagram with 1 wire alternator setup fo in reply to YYYYYY, 08-26-2006 14:57:58
One wire alternators sometimes do not work well on slow speed tractor engines. I would use a three wire Delco.
Kent
John T
08-27-2006 07:53:18
YYYYY YY If its truly a One Wire Alternator, MOST of them are for Negative Ground remember,,,,, ,,Sooooo o are you already at Negative Ground ??? and/or if not and you converted polarity, any ammeter leads would have to be swapped and if its a battery powered coil ignition instead of a Magneto, the coil leads would, likewise, need reversed. DO NOT HOOK UP THE ALTERNATOR OPPOSITE GROUND FROM ITS DESIGN....
Next, do you have an ammeter??? If not, I agree with my Old buddy, the alternators big main output stud wires to the batterys hot ungrounded post often at a starter switch or solenoid where the big battery cable attaches and Id use a 10 Gauge wire.
Buttttt tt if you have a working ammeter, then the alternators output wires to the Load (NOT to battery/starter) side of the ammeter. The ammeters other Suppyl terminal is what wires to the battery often at the solenoid or starter switch where the big battery cable attaches.
John T (Not sure whose older, me or Old, probably meeeee e???)
YYYYYYY
08-27-2006 07:58:25
 Re: Wiring Diagram with 1 wire alternator setup fo in reply to John T, 08-27-2006 07:53:18
John T.: Thank you for the reply to my inquiry. The information is what I needed. Thanks.
old
08-26-2006 15:45:47
Well if its a true 1 wire one then all you do is hook the wire from the big post on the alternator to the soliniod, battery side or the + post of the battery. Now if its a 3 wire post back and I can explain that also
