exhaust gasket leaking oil
drex
08-26-2006 09:53:05
When i run my wd-45 oil comes out the one exhaust gasket and down the side of the engine, could that be a bad head gasket or bad piston rings? thanks
old
08-26-2006 11:12:38
 Re: exhaust gasket leaking oil in reply to drex, 08-26-2006 09:53:05
Probably bad valve guides which when they leak will put oil in the cylinders and or in your case into the exhaust port of the head and then out the exhaust pipe and gasket area. I had one that did the same thing but it also had a lot of other problems
