WD belt pulley cover leaking. Help ASAP
Justin Squire
08-26-2006 07:23:07
The belt pulley cover has been leaking on my WD. I was wondering which oil the pulley uses. Is it connected to the hydraulic oil? Which drain plug do I drain in order to remove the cap and install a new seal?
Skibo
08-26-2006 19:32:09
 Re: WD belt pulley cover leaking. Help ASAP in reply to Justin Squire, 08-26-2006 07:23:07
I'm assuming that you don't have a belt pulley and just have the block-off plate. You are leaking tranny oil not hydraulic fluid. The easiest fix would be to drain some of your tranny oil off, pull that plate and clean behind it, throw a new gasket in there, top off the tranny and call it a day. There's a great big drain plug in the bottom of the tranny to do that. Shouldn't be a big deal.
