AC C/B carb adjustment???
shawnspeed3
08-24-2006 09:29:38
Have been trying to get a stutter out of my new to me C thatwas supposedly outfitted with an M&W pistion kit. Does anybody know if these kits were oversize? I have noticed if I play with the choke , I can get the tractor to run smoother, and there is no black smoke coming out the exaust. Have cleaned the carb and was clean as a wistle when taken apart,checked the jet,and Idle screw,all were clean.is the only way to richen the mix on this carb to upsize the main jet????and if sc does someone make bigger sizes?? is their another carb avaliable with adjustable idle ,and load circuts ,that will bolt on? thanx shawn
G Bahr
08-24-2006 18:48:13
 Re: AC C/B carb adjustment??? in reply to shawnspeed3, 08-24-2006 09:29:38
I beleve what "old" said is right had same problem on my D 17, pulled carb apart and had a garage boil it out over nite put a new kit into it and never had a problem again. Any ??? e-mail me [email protected] good luck!
old
08-24-2006 09:39:53
Had the same type of problem on my C. Carb looked good and clean but it wasn't. The passages on them can be hard to get cleaned out as good as they need to be. I took my carb apart 4 or 5 times before I got it cleaned out good enough to run correctly with out haveing to choke it.
RustyFarmall
08-25-2006 12:41:03
 Re: AC C/B carb adjustment??? in reply to old, 08-24-2006 09:39:53
Old, don't be afraid to use your torch tip cleaning tool and a can of spray carb cleaner. All of my carbs get the spray can treatment before I reassemble.
old
08-25-2006 13:11:19
 Re: AC C/B carb adjustment??? in reply to RustyFarmall, 08-25-2006 12:41:03
I use both of them plus soak them 24 hours in beemans carb cleaner and I also blow them out with 120-130 PSI of air. Just some carbs that don't like to clean up on the first try.
RustyFarmall
08-25-2006 14:19:28
 Re: AC C/B carb adjustment??? in reply to old, 08-25-2006 13:11:19
Yep, if I can't get the spray cleaner to come out somewhere when I stick the nozzle in another place, I know the carb is not clean yet.
old
08-25-2006 15:04:24
 Re: AC C/B carb adjustment??? in reply to RustyFarmall, 08-25-2006 14:19:28
Ya and even then sometimes its still not clean enough to have them run right.
