D17 series IV gas leak
Pete
09-01-1999 19:54:11
Have a problem with gas siphoning into the back cylinder when the engine is off. I have been shutting the gas off at the tank to keep this from happening, what do I need to look for in the carburator to keep this from happening.
Rick
09-02-1999 06:17:57
 Re: D17 series IV gas leak in reply to Pete, 09-01-1999 19:54:11
I would check the carb float and needle valve, it may be sticking open causing gas to continue to flow. The float may be bad or need adjusting.Good luck!
ROBERT
09-05-1999 15:25:06
 Re: Re: D17 series IV gas leak in reply to Rick, 09-02-1999 06:17:57
YOU CAN GET A CARB KIT AT YOU LOCOL PARTS STORE
IT IS E/Z TO DO.NEED TO CHECK FLOT TO MAKE SURE THERE IS NOT A HOLE IN IT. GOOD LUCK ROBERT
