wd seat shock
tim[in]
08-22-2006 10:10:23
i've seen posts on heere about using a shock absorber from napa for the seat.i wondered does it work ok without the spring like on the original? i had a used replacement one which got stolen when my pickup was stolen. along with the original. thanks in advance!
Texas Denny
08-22-2006 12:54:56
 Re: wd seat shock in reply to tim[in], 08-22-2006 10:10:23
The function of the shock absorber is to prevent oscillation. The shock does not support your weight. A shock from another application might work if it is the right size. If it is from a car, it will probably provide a fairly stiff ride as it is designed to work with a 500# load if it is a rear shock and 1000# if it is a front shock. Best chance would be a rear shock from a small front wheel drive car. You'd still need the spring.
These entire seats come up on Ebay pretty often. It would probably be cheaper and easier to get a used seat that way. Or maybe you can get just the parts you need.
