ac7020 powershift
Loon-Yi
08-20-2006 16:36:50
the transmission brake is not working very well: it can be quite difficult to get into gear. Cannot get the range shift to go into park either, any suggestions on what the problem(s) are, how difficult to fix?
thanks
cadet trooper
08-22-2006 15:50:59
 Re: ac7020 powershift in reply to Loon-Yi, 08-20-2006 16:36:50
Make sure you let up on the clutch just a little to release the clutch brake to allow the main shaft to free wheel as it will to allow the gears to release the tension on them because of their size they have to disengage. It's in the operators manual.Clutch brakes were pioneered 25 years ago as tractor hp and drive lines got bigger to allow for gear mass. But you may have other problems so this is just a suggestion. Good luck CT
Alan in Iowa
08-21-2006 13:30:45
You may need to adjust the clutch rod. The adjustment is behind the batteries. You also may need to lower the rpm while you are attempting to shift, I found I needed to do that even after making the clutch adjustment.
