Top dead center on AC -B
Dave
09-01-1999 09:59:56
Dad has read up on setting magneto, points, etc. but how do you determine when #1 cylinder is tdc on the compression stroke?
Dick L in NW Ohio
09-01-1999 11:08:09
 Re: Top dead center on AC -B in reply to Dave, 09-01-1999 09:59:56
I could not find the top dead center marking on my flywheel. I then took out the spark plugs to allow the engine to turn over easy. I then bent a wire at 90'0 3\4" from the end. Put my thumb over # 1 plug hole ( closest to the radiator) turned the engine over untill I felt pressure, put the wire in the plug hole and watched for the piston to change directions. Repeated untill I was sure I was at top dead center. Installed mag. set points so that they just started to open, set rotor to # 1 wire. Put plugs back in, put wires on in 1,2,4,3 order and it ran. Hope it works for you.
