WD - seems under powered
ShepFL
08-19-2006 20:25:27
When using 4' bush hog (trailer type) the rig seems to be laboring hard. Tonight I adjusted the carb and will do more work tomorrow.
Even running at full throttle in 2nd gear it would bog down in dog fennel. I can't even imagine plowing with it. Had to finish mowing with my Oliver 550 Dsl and 6' bush hog (3pth) with no issues.
I am thinking carb tuning/rebuild at this time and possble fuel line purge. Lower half of intake manifold (carb mount) seemed to be weeping water which I thought odd. Any thoughts on what type of performance I should expect?
Jerry Coulter
08-20-2006 10:50:45
 Re: WD - seems under powered in reply to ShepFL, 08-19-2006 20:25:27
Pull off the air cleaner hose to quickly check whether the air cleaner is clogged. If the power doesn't return, then drop the carburetor off the manifold and feel up into the manifold to see if there is a carbon build-up choking off the passage way.
hd6gtom
08-20-2006 07:17:05
Check your air cleaner, up inside the filtering element and make sure that isn't plugged up.
old
08-19-2006 20:43:23
Part of the problem sounds like good old carb iceing which is normal but a 4 foot hog that WD should just play with. Maybe a good tune up and carb rebuild might be just the thing it need. This summer I pulled a 5 foot with a WD45 and it just played with it till the in-line filter some one put on it clogged then I threw it away and it runs like theres no tomorrow now
