THANKS !!!!!!!!!!!!!
Guyzoo
08-19-2006 18:22:47
Thank you to all of you guys that helped me with my paint codes a few day ago. so I'll take the PPG 60080 from Dupont
THANKS AGAIN!!!
Rod (NH)
08-19-2006 20:09:04
 Re: THANKS !!!!!!!!!!!!! in reply to Guyzoo, 08-19-2006 18:22:47
The 60080 code is the correct shade from PPG. You now have several choices between different chemistries and "quality" lines, depending on your available safety equipment and how much you want to spend. Again, the 60080 is a PPG code number. It is not DuPont and has nothing to do with DuPont. The code of the closest shade to it from DuPont is YS074. By the way, these are automotive paints and are really not suitable for brush application. They are expensive, especially in the premium lines and they should only be applied with spray equipment. Most of the choices also require expensive respiratory equipment to safely apply them. If you want a brush application product that doesn't require special breathing equipment, look into a dealer paint from AGCO. I am advised that they now have that early persian orange shade available.
third party image Rod
