O.T. ants
LWD
08-18-2006 21:46:26
What do you boys do about ants in your fire wood
noncompos
08-19-2006 08:58:03
 Re: O.T. ants in reply to LWD, 08-18-2006 21:46:26
If it's in an enclosed place that no one is in much (shed, etc) drop in a few mothballs, broken into two or three pieces. Had wasps get into uninsulated wall once; drilled hole thru from inside, dropped in a few mothballs (taped inside hole): no more wasps. Good luck.
Henry M
08-19-2006 05:27:53
I quit fighting the problem of buggs in the firewood. I leave it stacked outside, bring a wheelborrow load and leave it in the cold garage, and from there it goes stright into the stove.
Vern-MI
08-19-2006 04:20:16
Squish them as they come running out of the fire. It's the dang mice and bats that give me the willies and they are fast too.
Too Far Gone
08-19-2006 04:15:24
Same thing I do for Uncles.I tell'em to get out of the firewood if they're not gonna help cut it.
BigMarv1085
08-18-2006 22:17:13
I would spread out some fire ant poison. They usually aren't much of a problem if the wood is stacked off the ground.
