'75-'85 allis tractors
Dave from MN
08-18-2006 16:12:18
Which Allis model (deisel) would be a good rowcrop tractor in the 75-110hp range for a small farm. Tilling up to 85 acres, and all that goes with growing a few crops on it. Would need to be a good starter in these cold MN winters for blowing snow and running generator as well. Not real familiar but with prices of red and green I am exploring other brands.
Hurst
08-19-2006 22:22:18
 Re: '75-'85 allis tractors in reply to Dave from MN, 08-18-2006 16:12:18
I bought a 7000 black belly that had a lot of bad seals in it. Now that most of those are replaced, it really runs like a top. The A/C is what really pays for this tractor. I wouldn't want to be on an open station in the dust and heat now that I have this tractor. I did have to replace the bull pinion shaft seals, which required a full rearend break down pretty much, but only about 60 dollars in parts I think, maybe a little more, but not much, just a lot of time... If you think you're considering a 7000, let me know, if you e-mail me, I can give you a lot of information and knowledge that I have learned through owning mine for 2 years.
Hurst
colomaAllis
08-19-2006 06:13:57
My dad has a 1978 Allis 7020 diesel tractor with Cab for sale. We are in central,WI. It's 120HP. If the batteries are good and the cables are good it starts easily.
JOHN HARMON
08-18-2006 20:46:51
A good suggestion [if one can be found] would be to find one of the later AC 190 gas tractors and I am sure it will satisfy you. plenty of power for a small Farm with 4 row equipment.They are easy to start in cold weather and gas usage is affordable. I used one for 320 acres of Corn,Oats and Alfalfa Ground and some Soybeans. It was operated along with a D17 and two WD45's but the 190 did all the heavy work very satisfactory.
WJ
08-18-2006 17:10:57
We have 3 tractors we use to run some hay ground. My brother-in-law does the actual work, he's the farmer among us and enjoys it. There is a 4010 diesel, a 4020 gas, and a recently aquired AC200. He is using the AC for everything, leaving the green set. He was disappointed when I did not buy another green one. I'd like a bit more road speed, but it starts and runs like a top, and is very fuel efficient. Book says it runs 14-15 MPH on the road, I don't know.
Aowner
08-18-2006 22:13:26
 Re: '75-'85 allis tractors in reply to WJ, 08-18-2006 17:10:57
I have operated several of the 190's and when they get alot of hours pulling heavy loads, they start jumping out of gear. Very expensive to fix. My neighbor has a 7000 and a 7045. The 7000 has about 700 hours and has had 6 water pumps put on it. The 7045 has about 2500 nad has had the transmission rebuilt once.
WJ
08-19-2006 08:08:27
 Re: '75-'85 allis tractors in reply to Aowner, 08-18-2006 22:13:26
It has a straight cut tranny, and that happens with careless gear grinders.
