Can you see my problem
Craig in MO
08-18-2006 15:28:45
third party image
This Universal wide front end says it is for a WC but was removed from a WD. It is going on my WD, I think. The problem is that it hits the steering post before it hits the frame. Is the WC narrower than the WD? I plan to put some 1/2 inch by 6 inch angle in there to fill the gap and allow me to use the lower set of steering box mounting bolts to secure it in place. Any others put one of these Universal front ends on? Thanks
Tramway guy
08-22-2006 08:38:35
 Re: Can you see my problem in reply to Craig in MO, 08-18-2006 15:28:45
I think it probably was removed from a tractor, but they left something on the tractor that should have gone with the wide front end. WC, WD, and WD-45 all have the same type of frame rails and the same width.
Chris(WA)
08-19-2006 06:06:28
Could you get some flat bar stock that was as thick as the gap between the frames and wide enough to bolt to both frames? Drill and bolt it in as an adapter. Easier to build than explain! Good luck!
Sid
08-18-2006 19:14:41
No I have never chaged one. But it seems to me that you are going to have to remove that pedestal.
