WC REAR END RATIO
OLIVER66PULLER
08-16-2006 21:11:54
ANY ONE KNOW IF WC/RC/WF HAD THE SAME GEAR RATIO
IN THE REAR. ALSO WHAT ABOUT A SPLITER BOX .
LWD
08-18-2006 21:41:44
 Re: WC REAR END RATIO in reply to OLIVER66PULLER, 08-16-2006 21:11:54
up till a cuple of years ago you could get a five tooth pinion gear for 238.oo dollars, the standard one was a sven tooth,they both used the same ring gear(32 teeth)you can go to the dealer and get a blue print and have one made. these were straight cut gears, a better ring & pinion would be a 1954 ford pick up with helical cut gears.you dont lose as much power with this newer gears.
Ken(MI)
08-17-2006 09:25:53
WC, and WF had 4.7:1 ring and Pinion, High crop WC, and RC had 6.6:1 ratio, the differential in the WC had four pinions, and the RC only had two, also, the RC pinion shaft used a support bearing on the outer end of the shaft. For pulling, I would reccomend using the early WC 4 pinion differential (pre 1938) as they use much stronger side gear pinions. Also, the RC pinion shaft can be ground to accept the support bearing, which I would also reccomend using.
