WD 45
Jud S
08-14-2006 15:44:33
I have another AC that has WD45 decals on it but it has a straight stick. The serial number is WD155014. Is it really a WD45 or has someone placed the wrong decals on it?
Thanks
John (MO)
08-15-2006 11:07:04
 Re: WD 45 in reply to Jud S, 08-14-2006 15:44:33
WD155014 sounds like the engine number and not the tractor serial number which is located on the back side of the real axle housing just below the left brake cover. The engine number of WD tractors started with WD and the engine number of WD45 tractors started with 45. Engine numbers do not match serial numbers of tractors, I guess because engines were used in other things.
Texas Denny
08-14-2006 16:35:12
Well, Jud, this one is a puzzler. The rear axel is certainly a WD-45 axel. The tranmission is certainly a WD. To determine which engine you have, check the right side of the block. If there is a plate bolted on the side of the block (running nearly the whole length of the block), you have a WD engine. If there is no plate, the engine is a WD-45.
It seems like you have a mixed bag. I'd let the engine suggest which it is.
