Retorquing head bolts
BJKM
08-14-2006 14:40:24
I need to retorque myead on a WD. Is it possible to do without removing the valve train. Could a crowsfoot be used to get to the bolts under the valve train?
Thank you in advance because I know many of you have been there done that!
B
Jerry Coulter
08-14-2006 14:54:00
 Re: Retorquing head bolts in reply to BJKM, 08-14-2006 14:40:24
It is best to take off the rocker shaft when you re-torque the head bolts. You have to readjust the valve train anyway.
BJKM
08-14-2006 15:45:19
 Re: Retorquing head bolts in reply to Jerry Coulter, 08-14-2006 14:54:00
Jerry-
Thank you for you quick response. I am going to heed your advice and remove the shaft. Thanks again
B
