WD welds are cracking on the wheels
kelly
08-31-1999 15:49:41
I've noticed the welds on the left rear wheel of my AC WD have started to crack. The wheel is not rusted. What would cause this, is it common, and can I simply reweld the crack?
GeneD14
09-01-1999 08:17:05
 Re: WD welds are cracking on the wheels in reply to kelly, 08-31-1999 15:49:41
Their are a number of things that can cause a weld to crack: wrong filler metal, rod selection, fatigue, temp, stress, joint design, etc... It is a good idea to grind out the old weld completely and have it rewelded properly and it should be fine.Good luck!
Rich Briggs
09-01-1999 20:31:44
 Re: Re: WD welds are cracking on the wheels in reply to GeneD14, 09-01-1999 08:17:05
I read in one of my manuals that when the power shift apparatuses were welded to the wheels that they were originally tack welded in place and as the final permanant welds were completed the tack welds often cracked from the stresses induced by the welding. If they look like just tack welds on the ends of the power shift bars the manual says not to worry about them.
Rich Briggs
09-01-1999 20:29:16
