1952 WD paint code
Guyzoo
08-12-2006 09:39:05
Hi, I am finally ready to pint my old WD. I've found two paint codes on this site but i don't know if they are no.1 Persian or no.2
One is: AC PERSIAN ORANGE 29047 Dulux from Dupont
The other is: AC PERSIAN ORANGE TP280 from TISCO
I would like if the one from dupont is the #1 persian and if these are PPG paints.
THANK YOU VERY MUCH!!!
steve(ill)
08-12-2006 15:21:45
 Re: 1952 WD paint code in reply to Guyzoo, 08-12-2006 09:39:05
i use the PPG 60080 paint for PO1. it is great stuff. Older version was DELSTAR and cost about $200 gallon. Newer paints they have a couple versions. Just make sure you get a hardener to go with the paint and use the automotive quality. I think the new PPG paints are OMNI and MAE, both ave very good and a littel cheaper than DELSTAR.
El Toro
08-12-2006 14:51:02
Here's a web site for tractor paint with PPG's paint numbers. I used the IH Single Stage red urethane on a Troy-Bilt tiller. Looks like new. Hal
http://www.worldpath.net/~thompson/misc/PPG%20Tractor%20Colors.htm
Rod (NH)
08-12-2006 13:59:29
Hi,
The 29047 is the later persian orange sometimes referred to as persian #2. 29047 Dulux is from DuPont, not PPG and is no longer available (at least in Dulux), the Dulux being DuPont's old alkyd enamel. You want the early persian orange (persian #1, so called) for your '52. If your preference is DuPont, you want YS074 as the closest match, in several different chemistries. If you want a PPG paint, you will want PPG 60080 for that early persian orange. I have more persian orange paint information on my webpage here, along with a visual comparison between the early and late "flavors" of persian orange. Scroll down for the paint section. There was a link in the paint forum at this site at one time for a visual comparison of DuPont's YS074 with some others. If you want, I can probably locate it for you. It was posted by Jason(ma) some time back in that forum. If he comes by here, he'll have a quick link to it.
third party image Rod
jason(ma)
08-15-2006 15:08:44
 Re: 1952 WD paint code in reply to Rod (NH), 08-12-2006 13:59:29
third party image
here is the almost finished product
jason(ma)
08-15-2006 15:06:17
third party image
this is with ppg's 60080 in concept and omni along with a napa code that I thought was close. I'd keep trying on the napa one if someone wanted to use that brand
Jason(ma)
08-15-2006 15:03:43
third party image
this is with duponts YS074 in Centari
Jason(ma)
08-15-2006 15:01:38
third party image
wow I'm being referenced. There is several pic that I took, What I did was to buy a bunch of the persian oranges out there and spray them out for a comparison. I ended up using PPG's 60080 in the concept line on my Allis g
JMS/MN
08-12-2006 13:31:43
Persian Orange #1 until 1960. TISCO, fleet stores, bumper to bumper, implement enamel, etc., is crap that fades soon. Get one that can match the Dupont, Centauri, etc. codes, or go with AGCO.
