WD 45 charging system - continued
ilrocketboy
08-12-2006 08:03:44
We have done some more work on our WD 45 that we cannot get to charge. We have 2 voltage regulators, but are not sure on the condition of either unit. The generator was polarized and checked, then with everything hooked up the ARM and BAT terminals on the VR were jumped to polarize the system (both regulators are pos/neg). Our tractor is running a negative ground. These are the results we are getting - normal running there is no charge. If we ground the field terminal, it charges high (by bypassing VR). Then, from another manual, we jumped the BAT and ARM terminals while the tractor was running and we got a heavy draw on the system, not a charge. It almost seems as if somehting is backwards. Also thinking that both VR"s are junk too. Any ideas from you guys?
steve(ill)
08-12-2006 15:26:51
 Re: WD 45 charging system - continued in reply to ilrocketboy, 08-12-2006 08:03:44
i assume you are using one regulator at a time. the good test for a charging system is to jump the F terminal on the generator to ground, if that works, then one of the contacts inside the regulator is burnt (probably). this appears to be your problems. you might take off the cover anc clean the points with fine sandpaper. the G terminal should be connected to the A on the generator, and the B goes to your ampmeter and other side of amp to the + battery terminal. I have a B with a 12 volt generator and it works pretty good, but got the clean the contacts every 3-4 years.
JMS/MN
08-12-2006 13:38:40
Why two voltage regulators? Original system had one relay on top of the generator, and it worked fine for decades. Are you using some components from a D17 with a regulator and 12v generator? WD45 had 6volt, positive ground from the factory. Time to decide which system you want to go with, follow the diagrams, and end up with something that works.
ilrocketboy
08-12-2006 15:39:42
 Re: WD 45 charging system - continued in reply to JMS/MN, 08-12-2006 13:38:40
We have 2 regultors at our dispossal, but we were only hooking one up at a time, seeing if the other one was bad. This tractor, when we bought it, had a 12v DR starter, 12v DR generator and the VR on it. We do not have a cut out relay that was used originally.
Is the method of jumping the ARM and BAT terminals on the VR an accurate way to polarize the system for EITHER + or - ground? My buddy told me that it sets itself to either one, depenidng on the rest of the wiring.
