WD gas tank replacement
uh oh
08-11-2006 21:26:22
anyone make an aftermarket reproduction gas tank for a WD? if not, who coats the inside of these nowadays? thanks!
Mike(MA)
08-13-2006 16:12:07
 Re: WD gas tank replacement in reply to uh oh, 08-11-2006 21:26:22
I don"t know of any vendors selling new tanks but most of the parts vendors can offer good used equipment.
As for the inside, you need to clean out the rust before coating it. Some folks use gravel, others prefer chains, and yet others go with a variety of bolts/nuts. Once you"ve got a handful or two inside, strap it into the truck bed and drive around for awhile. Remove the materials with the loose rust, clean it with a good solvent, and apply a coating. A few other people have had the tanks chemically boiled at a local radiator repair shop.
Lots of people recommend Kreme (motorcycle shops) but you can get it from Eastwood and other places as well. I used a product called Johnston Fuel Tank Liner from Restoration Supply.. it was about $20 and has held up well.
Mike
old
08-11-2006 22:05:38
I have a good used tank. As far as coating them you can do it your self all you have to do is buy the stuff and do it.
