WD45 narrow front wobbly
Kurt Gagnow
08-10-2006 20:22:58
Can anyone tell me how to fix this problem? My dad bought this tractor brand new, and I would like to use it more for small jobs on my dairy farm. But the front end is so woreout you can't drive it anywhere.
JMS/MN
08-11-2006 10:44:38
 Re: WD45 narrow front wobbly in reply to Kurt Gagnow, 08-10-2006 20:22:58
Jack up the front end to take the weight off, and it's easier to do what the others said.
Sid
08-11-2006 10:42:52
Most of the wobble that I have experienced has come frome the worn out key and keyway in the front pedesta. If you look betweetn the front wheels you will see the bolt and locknut that keep it in place.
Sid
08-11-2006 10:42:46
D17JIM
08-11-2006 10:01:47
I"m with Old, check the u-joints and couplings on the steering first. If that don"t do it the bearings on the vertical shaft of the front pedistal would be suspect. Also check the wheel bearings and hubs. The I T manual for my D17 explained how to fix all of these very well. You can get bearings at a local parts place very resonable. If all these fail you will be going farther into it than I have ever had to. Jim
old
08-10-2006 20:56:36
Are you sure its the front end and not the U-joints going bad. Theres 2 or 3 u-joints that can go bad and make it do that. Of course there are other thing but I would start there and also you should get an I-T manual AC-11 which would help you a lot.
