WD Carburetor Adjustment - HELP!!!
uhoh
08-10-2006 19:39:17
Got my 1950 WD allis home tonight. It starts pretty good, but it runs ROUGH. its blowing a little black smoke and laboring a bit, and at lower rpm"s it surges and pops. I believe its in the carburetor, and i put a kit in it. now my problem is, im stupid when it comes to tuning the carburetor. i know that the two needles are preset and i believe 1 and 1/2, but which do i tune first, and at what rpm"s? also, where the carb meets the intake is frosting up. what causes this and how do i fix it? i wish i could pipe it back for some Air conditioning, but ya know. thanks for your help.
Mike (MA)
08-11-2006 15:38:32
 Re: WD Carburetor Adjustment - HELP!!! in reply to uhoh, 08-10-2006 19:39:17
Not too long ago I asked a similar question for the Zenith on my C and got some very helpful advice from DickL and think that its what you are looking for. I"ve pasted it in below:
After it starts adjust the idle first. Turn the screw on the back of the carb to where it will run with the throttle lever by the steering wheel set all the way back. Adjust the screw with the spring (idle air mixture screw) to where it speeds up the engine. adjust the screw on the back side of the carb to slow down the engine as much as you can and still run. Then back to the idle screw and speed up the engine to its fastest rpm and then back to the screw behind the carb. Repeat this until you have the idle set to the proper rpm. Then to the screw with the T handle. Run the engine at full throttle and adjust to where it runs the best and then turn in until you hear the engine start to slow. that will be as close as you will get without the engine being under a load.
old
08-10-2006 20:53:29
Forst on the carb/intake is part of life and is normal. As far as setting the carb, the one setting up close to the manifold is the idle and you adjust it with the trottle set low and you want the engine to run as slow as you can get it to run with out dieing. The other one is the main jet and you set it so it doesn't put out black smoke but has the power you want. You have to play with them some to get them just right.
