Model C siezes up after 10 min. run time
Big C
08-09-2006 19:15:15
Have 1943 C hand start. starts runs great then siezes up after about 10 minutes run time. Blue smoke from around the rear main. I've done all I can Think of on the outside. Just would like any suggestions before I have to start a tear down.
Jerry Coulter
08-10-2006 09:41:14
 Re: Model C siezes up after 10 min. run time in reply to Big C, 08-09-2006 19:15:15
If no oil pressure, disconnect the oil supply line where it comes out at the rear of the filter base and prime it with a pump oil can by shooting down into the oil pump. If you have oil pressure, that indicates a cam bearing has spun blocking oil spray to a connecting rod and will require dissambly. :(
dej(JED)
08-10-2006 07:59:39
I had a B do that a while back. It would shoot the dip stick out of the side of the block. It was being caused by a clogged oil filter.
old
08-09-2006 20:12:17
How good or bad is the oil preassure?? No preassure means shut it down now. Also could be the problem. Need a lot more info to be able to help you much
