d17 hydraulic outlets
smorse
08-09-2006 18:01:02
oil leaking out of outlets on rear of tractor when hooked up to implement. any idea on how to fix this?
JMS/MN
08-10-2006 05:31:49
 Re: d17 hydraulic outlets in reply to smorse, 08-09-2006 18:01:02
Do the coupler halves match each other? Bad o-rings, or chipped balls? Balls may get chipped if the hoses are disconnected under pressure- ie, losing a hitch pin. Need to disassemble the coupler to check all ball surfaces. Barrels do wear over time, as well.
Rob NC
08-09-2006 18:26:49
We could never stop the oil leaking out of the remote coupling on a d-14 or d-15. Might just save you some pain to go ahead and replace them with pioneer couplings.
R.J.
08-09-2006 18:10:01
Install new (O)rings if that don`t work it new fittings. Hope this helps.
