WD Starter Brush and Spring Part Numbers
P.Isaac
08-09-2006 09:38:20
Just a bit of information for you folks fixing the Delco 6-volt starter used on the C and WD.
From NAPA, you need four brushes; Echlin R500.
Also NAPA, brush hold-down springs are Echlin SP6.
Advance Auto has the brushes as GP-Sorenson RX50 but has no listing for the hold-down springs.
Toby Wellborn
08-09-2006 18:33:40
 Re: WD Starter Brush and Spring Part Numbers in reply to P.Isaac, 08-09-2006 09:38:20
Do you have any part numbers for Allis B,C,WC,WD,WD45 Generators...
Thanks!
P.Isaac
08-15-2006 18:51:43
 Re: WD Starter Brush and Spring Part Numbers in reply to Toby Wellborn, 08-09-2006 18:33:40
Sorry, just reporting what I got when I was shopping.
NAPA associated stores have been pretty helpful. Even though they may not carry a part anymore, they don't even blink when I tell them "1953 Allis Chalmers".
However, the 6v-12v conversion information on>Link
has>Link some part numbers for condenser, coil, etc if you have a 12v converted machine.
noncompos
08-10-2006 14:58:26
FWIW, have 59 Niehoff parts catalog, shows 50-56 B,C,CA,WD,WD-45 and WF, Delco-Remy equipped, with var DR part #s for Dist 1111735 and 1111745, both 6V, for Gen,Strtr and Dist., but has no interchange listings. Will send if helpful.
