1950 wd hydraulics
dm
08-08-2006 09:14:20
My wd has the factory hyd.system on it.The lift arms are parallel to the ground and the lever is in the center of the quadrant.The system appears to have not been used for a long time.Also I am not quite sure how to work it.Does the pto have to be engaged?The lift lever does not want to move either direction.Is there some type of lock that I may not know about?Could the linkage be stuck or possibly something stuck in the control valve?
JMS/MN
08-08-2006 10:57:54
 Re: 1950 wd hydraulics in reply to dm, 08-08-2006 09:14:20
Best thing to do is get an operator manual, which has details on how everything should be set, according to what you want done. Linkages may be disconnected, plates set wrong, etc. To get further into the system once you know all externals are proper, then get the service manual (such as I&T AC 11) to work on the inside stuff.
Sid
08-08-2006 10:13:44
"Does the pto have to be engaged?The lift lever does not want to move either direction.Is there some type of lock that I may not know about?Could the linkage be stuck or possibly something stuck in the control valve? NO, NO,YES.
