821 AC hydraulic oil
Georgeharry
08-07-2006 19:09:15
Is anyone replacing there 821 hydraulic oil with dextron 11 or any hydraulic oil from a parts store?Do you know of any oil with the right specs.from any other than tractor dealers?Thanks
Hurst
08-07-2006 19:44:05
 Re: 821 AC hydraulic oil in reply to Georgeharry, 08-07-2006 19:09:15
Go to Autozone, Sams Club, Walmart, etc. They all carry tractor hydraulic-tranmission fluid. Make sure it is the hydraulic-transmission fluid and not just plain hydraulic fluid. Then check the lable and it should tell you if it meets the specs, which most all of it does. I bought a 5 gallon pail of coastal Multitrac fluid for 28 bucks at autozone. I use it on my 7000 black belly which has a powershift, wet PTO clutch, and uses one of the clutch packs as the drive clutch (inching pedal). Good luck. I know the dealer I went to wanted about 60 bucks a pail, a little much for me
Hurst
Georgeharry
08-08-2006 20:22:41
 Re: 821 AC hydraulic oil in reply to Hurst, 08-07-2006 19:44:05
Thank you Hurst for the information.Georgeharry
