WD45 hold position valve rebuild
Doug
08-30-1999 08:39:04
I rebuilt my hydraulic pump last fall and it is working fine. I did not attempt to rebuild the hold position valve. I must rebuild it now since it has stopped working and will not hold at any position. Does anyone have any advice, recommendations etc? I am concerned about getting the old valve seat out of the valve body.
Thanks in advance for the help.
Matt scott
08-31-1999 22:15:23
 Re: WD45 hold position valve rebuild in reply to Doug, 08-30-1999 08:39:04
Well the i&t manual says not to remove the seat it unless you absolutely have to. But if you do have to remove it i beleave that your supposed to drill and tap it so you can stick a bolt in it to remove it. I worked on a few hold valves this summer and never had to remove the old seat, i just took a brass punch and gave the ball one swift blow to reseat it and they all work fine. Hope this helps Matt scott
