Allis B oil
john morris
08-06-2006 23:56:33
I droped the oil in allis gear box at the week end, and got one bucket of water very little oil out!! there are two drain plugs, but only one filler plug ?? does this mean you have to fill in two places, also how does one change the final drive oil, do you have to remove the two oil pans and fill through the two small plugs at the side ? there is nothing in my manual to explain how to change the oil
steve(ill)
08-07-2006 18:43:02
 Re: Allis B oil in reply to john morris, 08-06-2006 23:56:33
the transmission/ pto holds about 8 quarts of oil. the new universal hydraulic transmission fluid is a good thing to use. You shoudl plan on getting 4 gallons. put 2 gallons in and run a hour or two, then drain and put the final fill in. the water will have some hideout and you will see contamination on the first fill. finals use 80-90wt gear lube.
Rod (NH)
08-07-2006 07:21:02
Hi John,
If you have a PTO assembly designed for a hydraulic pump there are actually three drain holes - two for the transmission/differential and one for the PTO. There is only one filler hole. That is all that is needed. The multiple drain holes are to permit draining "dead" pockets that will get filled when the level is correct at the single fill hole. As far as the final drives go, yes, you do have to drop the pans to change the oil. You should plan on having to make replacement gaskets and you might want to consider adding a drain provision to make is easier for the next time. That's what I did as shown here.
third party image Rod
john morris
08-07-2006 23:50:31
 Re: Allis B oil in reply to Rod (NH), 08-07-2006 07:21:02
Thanks again for your help, I will get straight on with it, one more question that you might be able to help me with, I have just purchased a set of decals, but no instructions, any advice on how to fit them as I dont want to spoil my new paint job, would a splash of washing up liquid help to allign ?
Rod (NH)
08-08-2006 13:22:54
 Re: Allis B oil in reply to john morris, 08-07-2006 23:50:31
John,
It depends on the type of decal(s) you have, mylar or cut vinyl. Some kits (usually the more expensive ones) have a combination of both. If that is the case, the main hood decal is usually the cut vinyl type with individual separated letters held together in proper alignment by a top and bottom covering. The remainder are generally all smaller, mylar types. The cut vinyl type should be applied dry, with alignment and applications instructions as shown here. The mylar style can be applied wet and shifted around slightly if needed after they are down although the smaller ones are generally easy enough to apply directly w/o wetting. The cut vinyl type should have a backing on the bottom and a partially transparent covering over the top of the decal. The mylar type should only have a backing on the bottom. I have read about using dish washing liquid as an additive when applying mylar decals but have never tried it myself so I don't know how it works.
Rod
