WD45 Cylinder Head
Toby Wellborn
08-06-2006 16:19:54
Does anyone have a photo of the cylinder head tighting sequence for a WD45 or know where I might find one on the web.
Thanks! Could not locate anything in the I&T Shop Manual AC-11...
Sid
08-06-2006 20:19:40
 Re: WD45 Cylinder Head in reply to Toby Wellborn, 08-06-2006 16:19:54
Here it is. From I&T Allis Chalmers shop manual AC-11 page 14 Paragraph 66. "When reinstalling,tighten head nuts or cap screws progressively and from the center outward. Retighten after engine has reached operating temperature. ....Tighten models WC,WD,WD45 and WF 1/2 inch studs to 70 foot pounds and 3/8 inch studs to 25 foor pounds torque."
old
08-06-2006 19:32:16
Texas is on the mark I have also never seen one. What I do is look at say a clitons manual you do it like you would a 4 cylinder car engine. I don't have to look at them any more but I have been doing engines for 30 plus years so I know about how it should be done
Texas Denny
08-06-2006 18:50:07
I've never seen one. Usually it is common to start at center and work your way to both ends together. I do them the first time at about 50 to 75% of the spec and then repeat the same sequence to spec. After getting it warm, your supposed to pull the valve train and torque a third time. I've did that on several and it didn't make them any tighter. So lately, I've just done the ones that can be tightened without removing the valve train. If they are loose, I pull the train and do as prescribed by Allis. If they are tight, I skip this step.
