I am all for supporting ourselves, as farmers, and as a nation, by burning alcohol fuels in vehicles designed for them. However, at this time, there is no economic advantage to doing so, because, even though E-85 is cheaper than unleaded gasoline, most, if not all the $$$ advantage is eaten up by the increased amount of E-85 burned, because of it's lower energy value. I think the low compression ratios of old tractors would make it's efficiency even worse. I really doubt you'd have trouble doing what you are proposing, at least in the short run, however, I suspect the alcohol blend will go out of condition and turn nasty, and corrode and gum things up, if the tractor ever sits unused for a period of time with the alcohol blend in the gas tank. So, while burning the alcohol fuel is a patriotic and "warm and fuzzy" thing to do, I don't think it will make keeping fuel in your tractor any easier on your wallet! That being said, my next pickup will be a "flex fuel" vehicle.
