1940 AC B
TV
08-05-2006 18:32:14
I HAVE JUST BOUGHT A 1940 ALLIS CHALMERS B. THE DISRIBUTER HAD BEEN REMOVED AND IT IS OUT OF TIME. COULD SOMEONE GIVE ME THE FIRING ORDER AND INFORMATION ON HOW TO TIME IT. THANKS VERY MUCH.
steve(ill)
08-07-2006 20:16:02
 Re: 1940 AC B in reply to TV, 08-05-2006 18:32:14
take out the front spark plug. roll motor over by hand untill it is at TDC on the compression stroke, with your finger over the plug hole you will feel the pressure. look for TDC on the flywheel mark on the side of the flywheel housing thru the 1 inch hole. set the mag so it "snaps" and points at #1 wire at this time.
http://dueyschutter.freeservers.com/photo6.html
old
08-05-2006 19:17:45
Well first off get #1 cylinder up to TDC, its the one by the radiator if you didn't already know that. Fireing order is 1,2,4,3. If you need more info just ask
