allis b rpm fluxing up and down when you give it
ny mike
08-04-2006 18:16:46
Just wanted to thank the guys that helped me get it going. But now the rpm goes up and down when you give it 1/2 to full power. But if you grap the goveror rod and hold it, it will smooth out. It like the govenor is sticking but the linkage moves freely, no binding. the tractor has been sitting for a while. It will idle smooth and if you grab the linkage on the carb it respond with what ever you do so I think it in the govenor , is out of adjustment and how do you adjust it???
ny mike
08-07-2006 05:57:21
 Re: allis b rpm fluxing up and down when you give in reply to ny mike, 08-04-2006 18:16:46
Rod (nh) , Thanks for the photo, that told the whole story. No I dont have that spring but I know what I need know, thanks to all again. Mike
old
08-04-2006 19:11:20
You have probably got bad springs etc in the govanor but the only way to be sure is to open it up
chalmersbob
08-04-2006 19:10:35
do you have the spring on the rod at the carb?
one end goes thru a hole in rod and the other goes on a manifold bolt just front of the rod hole.
Bob
ny mike
08-05-2006 05:58:52
 Re: allis b rpm fluxing up and down when you give in reply to chalmersbob, 08-04-2006 19:10:35
no , i never had a spring, and I looked and dont see were it would go ????
Rod (NH)
08-05-2006 06:28:33
 Re: allis b rpm fluxing up and down when you give in reply to ny mike, 08-05-2006 05:58:52
This is the spring that Bob is talking about:
third party image
I have seen the correct spring on Ebay regularly for a reasonable price. You need to blindly hook the large loop up behind the manifold and over the manifold stud shown. It is sometimes referred to as an anti-surge spring as the purpose is to dampen surges and keep the governor from "hunting". The correct, official name however is "carburetor link spring", AC part #212321.
third party image Rod
Chris Jones
08-05-2006 20:43:38
 Re: allis b rpm fluxing up and down when you give in reply to Rod (NH), 08-05-2006 06:28:33
I had the same problem and that spring will fix it.
