WD rear wheels and rims and steering question
mike in wv
08-04-2006 16:22:02
I am looking for a power adjust wheel and rim for a WD. Are any wheels from other Allis models compatible?
Also the steering wheel turn 2 full times before turning the wheels. The U-joint on the shaft appears to be Ok. How difficult Is it to take apart the front end? This is a standard tricycle front end.
chalmersbob
08-04-2006 19:14:59
 Re: WD rear wheels and rims and steering question in reply to mike in wv, 08-04-2006 16:22:02
there is a bolt between the front wheels that holds the tee on the down shaft. jack up tractor, remove wheels and remove the bolt. there is a keyway that holds the parts tight. might be bad. can also remove top plate in front of radiator and check for play there. Bob
