4th Gear
John Bracher
08-03-2006 21:51:45
My 1956 WD45 jumps out of 4th gear on the road.Any idea on how to cure this problem. Thanks.
Fredd
08-09-2006 06:41:09
 Re: 4th Gear in reply to John Bracher, 08-03-2006 21:51:45
My WD45 jumps out of third when holding back going down hill. The solution: use second. In your case I would advise using third instead of fourth. If you mean the shifter slides out from between the forks that is another story. I have had success in gobbing some weld on the bottom of the shifter, then grinding it down to the propper size.
John Bracher
08-09-2006 22:12:44
 Re: 4th Gear in reply to Fredd, 08-09-2006 06:41:09
Fredd, Thanks for the tip on welding the ball up then grinding it down. A bungie cord will hold it in place,but i would like for it to work correctly. Thanks again, John
