live hyd. on wd allis
Scott Mullinax
08-03-2006 19:59:03
What are some ways to add a live hdy. system to a 1952 WD Allis. I need two way use.
Arkansas Bill
08-10-2006 09:18:23
 Re: live hyd. on wd allis in reply to Scott Mullinax, 08-03-2006 19:59:03
What capacity pump (gallons per minute) would you recommend?
JMS/MN
08-03-2006 23:15:08
You have live hydraulics with the factory system, but it sounds like you want independent hydraulics with more capacity. You can change the front pulley to a double sheave, the one used for power steering on a WD45, and mount a belt-driven pump below the engine. Pulley is hard to find, and spendy. You can machine the existing pulley to accept a stub shaft to drive a front pump, using either a lovejoy coupler or a double sprocket. Used to be a clamp-on pulley available to create a second sheave, but that was not sturdy. Better to machine a flat surface, weld on a stub, and machine it so it runs true.
Buddy in A
08-30-2006 09:21:25
 Re: live hyd. on wd allis in reply to JMS/MN, 08-03-2006 23:15:08
my hydralics suddenly quit working on WD. Any suggestions as to what to look for? It is not low on fluid.
old
08-03-2006 20:32:43
2 ways a front mounted pump or a pump run off and crank shaft pulley, with a belt. Either one will work not sure how to do the one but the other isn't hard but will cost you some bucks
