Model G Brake question
chiefrider
08-02-2006 19:48:33
Hello.I have a brake pedal that goes all the way to the ground.This tells me the shoes are worn or the drum is worn or both.Linings are not down to the rivots.Am I correct that they are shot or am I missing something else.The other side seems fine.Took apart and shoes do move out.Any help?
Dale(MO)
08-03-2006 00:55:15
 Re: Model G Brake question in reply to chiefrider, 08-02-2006 19:48:33
Yes, the shoes are worn out. It is amazing how adding 3/16" of shoe material will make the pedal only move an inch or two.
As long as the rivets haven't gotten into the drum and eaten it up, just replace the shoe linings - pretty cheap and easy fix. The drums - take good care of them, they aren't so cheap and easy.
Good luck,
Dale(MO)
Don L C
08-05-2006 20:17:24
 Re: Model G Brake question in reply to Dale(MO), 08-03-2006 00:55:15
Dale ---
Where do you get your brake linnings for the G ?
thanks Don
