Remove Replace Clutch
Stan (NCMO)
08-02-2006 13:39:11
I"m going to replace the pressure plate and throw out bearing on my D15, II. Does anything else need replacement while I"m there?
old
08-02-2006 13:59:38
 Re: Remove Replace Clutch in reply to Stan (NCMO) , 08-02-2006 13:39:11
Do it all throw out bearing, preassure plate, clutch disc and pilot bearing. That way you know every thing is new and less likely to go back out on you. Also watch which way the disc comes out and make sure the new one goes in the same. If you put it in backwards it can/will cause you problems BTDT and cost me big time.
Stan (NCMO)
08-03-2006 16:01:55
 Re: Remove Replace Clutch in reply to old, 08-02-2006 13:59:38
Thanks for info, that was what I was thinking.
old
08-03-2006 16:28:22
 Re: Remove Replace Clutch in reply to Stan (NCMO) , 08-03-2006 16:01:55
You also might look at haveing the flywheel turned if it has any ridges or burned place on it. It only cost about $10 to have it done and can be well worth it in the long run
