Location of WD/WD-45 Serial Number
Retcol
08-02-2006 02:02:29
I am not knowledgable about AC tractors. Can anyone tell me where to look for the serial number on a WD or WD-45 tractor?
old
08-02-2006 07:04:09
 Re: Location of WD/WD-45 Serial Number in reply to Retcol, 08-02-2006 02:02:29
As Bent says and also if you look on the right hand side of the engine, if it has a plate that bolts on its a WD engine and if there is no plate its a WD45 engine. Either engine can fit in either tractor and overthen year who know what has been done to a tractor.
Badly Bent
08-02-2006 02:05:03
It will be located on the left rear axle housing just above the top lift mounting bolt. It is stamped in and can be difficult to read. Sometimes, if the tractor has been repainted, you have to scrape away the paint (or the rust if it hasn't been repainted).
Tim
