Allis late WD thermostat
Justin Squire
08-01-2006 18:55:30
I am restoring a late WD (curved shifter and plate on side of engine) and I am having trouble with the thermostat housing, first, It looks to be cracked, does anyone know what material this is so maybe it can be welded, second, I have a bolt stuck in it but it is not in the threaded part, should I heat it to get it out? Also, does anybody know if the late wd's and wd45's had thermostats on them. I have two tractors, one an early wd and one a late. I only removed one thermostat between the two of them. It came from the oldest one. If it did have a thermostat, does anyone know where I can purchase a water outlet assembly with thermostat?
Thanks
old
08-01-2006 19:12:36
 Re: Allis late WD thermostat in reply to Justin Squire, 08-01-2006 18:55:30
I would probably have that part you need. I have 2 WD/WD-45 engines for parts. One is a WD45 engine and the other is a WD engine but I think the part is the same on both of them. E-mail is open. I also have a number of other parts for WDs
Toby Wellborn
08-01-2006 19:11:00
I just ordered a new thermostat housing for a 1955 Allis WD45... They are a AGCO and old Allis Dealer
Good Luck!
Try:
SANDY LAKE IMPLEMENT CO.
Rt. 173N--3675 Sandy Lake Rd.
Sandy Lake , PA
16145-9803
Phone: (724) 376-2489
Fax: 24 hrs, (724)376-3775
Store Hours: Mon - Fri 8:00 A.M. to 5:00 P.M. Sat 8:00 A.M. to noon. E.D.T.
email: [email protected]
